L'univers du Scooter Forum Index
L'univers du Scooter Forum IndexFAQSearchRegisterLog in
:: comment vidanger la transmission d'un ludix?? ::
Goto page: <  1, 2
Post new topic   Reply to topic    L'univers du Scooter Forum Index -> -SCOOTER- -> Problèmes et Choix
Previous topic :: Next topic
Author Message
Offline
Moyenne de points: 1.00
PostPosted: Wed 30 Dec - 00:39 (2009)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
Ah bon ? Possible mais c'est pas vraiment necessaire , surtout si tu fait du all days
Back to top
Visit poster’s website MSN
PostPosted: Wed 30 Dec - 00:39 (2009)    Post subject: Publicité
Back to top
dydy59
Offline
Masculin Vierge (24aoû-22sep)
Point(s): 28
PostPosted: Wed 30 Dec - 00:44 (2009)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
ui all days mais enfaite jtesplik jai sérré 2moteurs en 1semaine et on ma di ke javais ptetre une merde dedans psk lé 2 piston a pratikement lé meme degats mais demain jachete kit 50 conti donc jespere ksaa ira mais kom jdemonte tout joré voulu savoir komen faire pour repartir avc un kit ki ne lache pas au bou de 2ookm
Back to top
Offline
PostPosted: Wed 30 Dec - 01:01 (2009)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
AH et bien il fallais le dire sa . Tu as une photo d'un des deux piston ?
Back to top
dydy59
Offline
Point(s): 28
PostPosted: Wed 30 Dec - 01:03 (2009)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
euh att jvé faire la photo du dernier
Back to top
dydy59
Offline
Point(s): 28
PostPosted: Wed 30 Dec - 01:09 (2009)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
jcroi ksé bon pr la photo
          l
          l
          l
          l
Back to top
dydy59
Offline
Point(s): 28
PostPosted: Wed 30 Dec - 01:11 (2009)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
Back to top
Offline
PostPosted: Wed 30 Dec - 01:12 (2009)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
je pence pas que sa viennent d'une merde de ton bloc ..
Back to top
dydy59
Offline
Point(s): 28
PostPosted: Wed 30 Dec - 01:13 (2009)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
jespere... Embarassed
Sinon sa a l'air dettre la merde a tout demonter ...
Demain je mets mon kit et si sa ressere je le metré sur le forum
Back to top
dydy59
Offline
Point(s): 28
PostPosted: Wed 30 Dec - 01:14 (2009)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
ta pas des teknik pr bien monté un kit??
Back to top
Offline
Point(s): 8,388,454
Moyenne de points: 26,213.92
PostPosted: Wed 30 Dec - 02:06 (2009)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
LOL ya pas de technique les Ser clip ce defon pas ? Donc le piston es bien monté
tu look que la fleche soi coté échap
tu passe un cou dessence dans le bloc (carter ) tu fai touné le vilo av le kick  (en kikan)
ensuite tu fou de lhuil av le doi sur les segment tu les place bien
tu frote l'interieur du cylindre a lesence un coup et ensuite a lhuile tu le calle sur le piston tu mets bien les segment
et c bon la cullase tu la vis en X en croix Voila que ça a faire !
pour la purge tu ouvre la tranmi av les btr et c bon
Back to top
dydy59
Offline
Point(s): 28
PostPosted: Wed 30 Dec - 02:09 (2009)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
ah merci pour lexplikation =) =)
Back to top
dydy59
Offline
Point(s): 28
PostPosted: Wed 13 Jan - 20:25 (2010)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
Sé bon jai ouvert mon BM et jai changé mes roulements jai monté kit 50 origin conti avc un pti vario polini : )) et sa tourne denfer !!!
Back to top
dydy59
Offline
Point(s): 28
PostPosted: Sun 24 Jan - 19:36 (2010)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
maintenant mon scoot a roulé 150km et un jour jle rentre chez moi dix min plus tard jveux repartir et il demare pu estce que sas peut etre le boitier cdi?
Back to top
dydy59
Offline
Point(s): 28
PostPosted: Wed 17 Feb - 01:35 (2010)    Post subject: comment vidanger la transmission d'un ludix?? Reply with quote
Up
Back to top
Display posts from previous:
Post new topic   Reply to topic    L'univers du Scooter Forum Index -> -SCOOTER- -> Problèmes et Choix All times are GMT + 1 Hour
Goto page: <  1, 2
Page 2 of 2
Jump to:
Index | Xooit.com free forum | Free support forum | Free forums directory | Report a violation | Cookies | Charte | Conditions générales d'utilisation
